[SOLVED] Question about cleaning TN Panel
Kurobuta
37
Hello! So I have the ASUS VG258QR monitor and was wondering how would I clean a TN panel? I saw some smudges and some are just very difficult to remove with just a microfiber cloth.
A soapy solution, made with water and mild soap on a microfiber cloth will help in removing the smudges. The smudges you speak of are often oils left from our fingers while. Also be gentle when wiping the panel(the surface of it at least).
Reactions: Kurobuta
