Hello! I purchased a Corsair RS140 fan, which (among other things) comes with an ARGB connector for the motherboard and another one that allows you to connect multiple fans together.
That second connector (which I'm not planning to use) comes with a plastic cap covering the header's pins. The question is: should I leave the cap on, or I should remove it instead?
I'm afraid of removing it and causing an electrical short or something if the headers' pins touch the case or the motherboard. Would the plastic cap burn, melt or something if I leave it there? What do you recommend?
