Hi everybody.
Question about voltage and tempratures on my i7 6700K. Help would be very appreciated.
Here is the TL;DR for people who don't want to read the entire post:
Question 1) Why does every program in Windows show a different temprature, and why does it fluctuate like this?
Question 2) Is it harmful for the CPU to run on 1.3 (1.296) Volts, or should I keep it on 1.2 Volts manually?
I'm running an Asus Z170 Pro Gaming motherboard with a i7 6700K
For question 1:
I've build this PC about 3 to 4 years ago and noticed this same issue, however it seemed to be resolved, untill I now recently resetted my BIOS settings after reinstalling Windows. (chose to do this because I wanted a clean and as-new PC).
Basically every single program I install on my PC which is capable of monitoring tempratures , shows another value. Tried running them at the same time, tried running them seperately, but that doesn't change anything. HWMonitor is showing about 30c up to even 60c when the PC is baiscally ideling (only running HWMonitor). And even in idle it keeps jumping up and down between those numbers like a maniac.
I have configured the chassis fans to spin at certain temps with Q-Fan in the BIOS. It works, but also here noticed they spin up much later than HWMonitor indicates that the given tempratures for the fans to spin up, has been reached.
I'm wondering what is going on, and what to trust. In the BIOS the temp seems to be stable, mostly somewhere around 20 to 40c, but in HWMonitor it jumps like crazy.
For question 2:
So like I mentioned before, I have reset my BIOS settings. I was looking around for a bit and I've noticed that the motherboard gives the CPU 1.296 volts.
Online I've found multiple sources saying an 6700K should run on 1.2. So I have configured it to run on 1.2 on Manual mode now (which I believe I already had, before resetting the BIOS settings). But on Auto mode it does nearly run the CPU on 1.3 volts. Is this bad? And should I set it back to Auto, or leave it manually on 1.2 Volts?
Thanks to everybody reading this. Hope someone can clarify things for me in this situation.
Hoping to get some answers
. If any pictures of the BIOS configuration are needed to offer better help, please let me know.
For question 1:
For question 2:
