They are proprietary on those small cases and won't find an exact fit most likely unless you get the same one. The real question is do you have the 745 SFF or the USFF. The SFF just one the one CPU fast right in the middle. The USFF have two small fans on in the front and one in the back on the bottom.
The SFF uses a 80x80x38 which a normal fan is 80x80x15 which WILL work if you get one. They use Rubber Garments to hold those in. As far as brand goes I like cooler master fans.
The USFF uses a 60x60x38 fan and is also held in my rubber garments so you can get a thinner fan. Not sure of what brand to get or who all carries this size.
Now the thing you have to look out for is they have again a proprietary 4 pin connector. Normal fan...
