Hello everyone!
first of all my specs are:
amd athlon 64 X2 6000+
vista home premium 32 bit
3GB RAM
500w power supply
I just purchased a new HIS Radeon 4890 HD Turbo video card. I've noticed that it has been stuttering
and performing slowly. COD4, Crysis etc. run at 25-30 fps. When I installed the card, I noticed that there are
two different connector ports on the card. One is a 6 pin PCI-e and the other is an 8 pin PCI-e. My power supply only has two of the 6 pin connectors, and does not have an 8 pin connector. The manufacturer supplied in the box a 4 pin molex (x2) connector adapter, which then gives me the 8 pin connector. But also in the box contained a small sheet saying that the adapter can be used but is not recommended.
Could this be the reason for the stuttering? I've already flashed my BIOS, cleaned out old drivers with driver cleaner pro, reinstalled the ati drivers a few times, and I tried changing the settings in catalyst control center for performance.
any help would be greatly appreciated 😀
3GB RAM
500w power supply
