So my gpu was working fine, i went out and shut the pc down when i got back the gpu seems to run for a minute or two then kaput, when i looked at the task manager before it shuts down it hits 100% (probably overheat but its an older amd gpu (r7 360) and running at 60-70 degrees is pretty normal imo) I'll probably just get an upgrade since the gpu is 7 year old.
Also i want to ask about a temporary gpu, should i use a r7 240 2gb or hd 7790 1 gb ?
