[SOLVED] Random Low Frames and Stuttering on 1080ti / 8700K Rig
Sep 11, 2019
Hey, I have a pretty peculiar issue. So, I’d say about 1 week ago I noticed that my performance in all games tanked hard. I have been troubleshooting since last night and at this point, I really cannot figure this out on my own. So basically, my game performance prior to this issue was perfect. Rainbow Six Siege always ran between 180-220 FPS, CS:GO would run 250+ frames all the time, BFV would run between 140-180 most times, etc. Basically, I would get the expected performance for an 8700K +1080ti rig at 1080p. So last week when I launched CS:GO, I noticed the frames would hover between 90-100. When I got in a match, I faced extreme stuttering and frame drops, the game wasn’t smooth at all. Then I tried Rainbow 6 Siege and the same thing would occur, the frames were around 80-110 FPS with extreme stuttering. I tried most demanding games in my library like Doom and GTA, etc. All showed the same performance.
This is what I did (in order) for troubleshooting:
-First, I reinstalled my Nvidia Drivers. Wiped them out with Display Driver Uninstaller (DDU) in safe mode then reinstalled
-Next, I tried running games while closing certain apps. I would close google, Corsair iCue, Logitech G-hub, discord, Afterburner and Riva statistics, precision x. Basically I would close all background apps in my system tray except those required for launching a game like steam and Uplay, etc
-Next, I uninstalled a windows update. There was one from last week or so that was causing 100% CPU usage I believe and was causing issues with the search bar and Cortana. Although I did not have these issues, I uninstalled that update anyway and tried running my games again, but the performance stayed the same.
-Next, I ran CCleaner because at that point I thought there might be a virus or something causing the lag, that didn’t work either
-Lastly, I reinstalled windows. I was planning to anyhow so I just did it last night convinced that would fix whatever the problem was. Unfortunately, it didn’t work either.
So now here I am.
Here is some gameplay to show what’s happening. Notice the erratic FPS graph.
Rainbow Six Siege:
https://drive.google.com/file/d/1UByn7hAohB5ziD2i9CHbYx01ecamAtio/view?usp=sharing
CS:GO: https://drive.google.com/file/d/1yhUw_gQmBJCn9faxuUf314Hb6IS3n2JJ/view?usp=sharing
Battlefield V: https://drive.google.com/file/d/1qYZfNFJ--CsGTHPt5lEOM3Kp9ZhwN-Sp/view?usp=sharing
3D Mark Fire strike Score: https://drive.google.com/file/d/1xVWUX7l7fWvWtECuM8IsDqRFhZM40-KG/view?usp=sharing
Unigen Superposition: https://drive.google.com/file/d/1arqXna3l7rZ6iGGPuuUen5OXts4UjpYu/view?usp=sharing
HWinfo TXT file: https://drive.google.com/file/d/1cvnIZS895PbXaR25rAXkr8mDBYiD42Vr/view?usp=sharing
HWinfo Screenshot: https://drive.google.com/file/d/177SPOwOYxh9iIBM0Ds_I1h-pL7RMXVth/view?usp=sharing
I greatly appreciate any and all help. If there’s any more info on my system that I need, please let me know, thank you!
Try putting your 1080ti in a different slot. Sounds like some settings got changed via Geforce Experience or you could have a temp throttling issue as well. Take a look at HWMonitor to see if some temps are 90C+
