Made a new pc build today.
CPU: Ryzen 5 5600X
CPU Cooler: Coolermaster Hyper 212 Evo V2 62 CFM
Motherboard: MSI MAG B550 Tomahawk
Ram: Corsair Vengeance RGM Pro SL 32gb (16x2) DDR-3600
HDD: WDBlack 4TB 3.5" 7200RPM
SSD: Crucial P1 1TB m.2-2280 NVME SSD
GPUL: EVGA GeForce 3060TI 8GB FTW2 Ultra Gaming
CASE: Lian Li LANCOOL II-W ATX Mid tower
PSU: Thermaltake Toughpower GF1 PE 750W 80+ gold certified
Upon turning it on red lights would flash on the GPU (I'm guessing not adequate power), at the same time lights below the GPU on the motherboard would flash green AND blue.
I later observed the Debug LEDs and the CPU light would blink indicating CPU was unable to be detected.
Each time I attempted to power on via power button there would be an audible "TOCK" sound that would go off and following that all the lights that did turn on would all turn off as well.
At first I thought the CPU issue was the 5600X not being supported by the B550 Tomahawk so I attempted a BIOS Flash, when attempting the BIOS flash I noticed the same thing would happen in that when I held the button down to perform the BIOS flash, the light would appear just below the flash button and on the mobo but the audible TOCK would go off and both lights would cease to blink immediately.
After attempting the BIOS Flash I tried to power the system again, this time on top of existing lights flashing and audible tock the fans would also attempt to spin up and move as well as the front case RGB would light up a bit.
I'm currently stumped between whether its a PSU or a Mobo problem and potentially CPU
Example of what happens on pressing power button:
When I try to start
Suggestions I got:
What do the experts think?
Much appreciated for any/all help and suggestions!
CPU: Ryzen 5 5600X
When I try to start
Suggestions I got:
- PSU of 750W isn't enough
- When attempting a BIOS Flash unplug everything but Mobo
- Ram is in incorrect slots
- Booting without GPU
