jandertaker
nitrium :
vflow :
Same issues on my new Ouroboros, bought 13th (hmm!) of February 2013. Here is part of my conn with Razer Support:
"OS Win 7 Ultimate x64
1. When changing from wired to wireless mode mouse freezes. Only solution to restore the mouse functionality is to log off-log on which means the game session is compromised.
2. I am using Razer Goliathus Control Edition mouse pad. Despite the calibration for this pad it seems that Synapse cannot remember the settings so each time I start the computer I find different settings under Calibration tab.
3.After mouse stand-by mode on wake up, it becomes unusable, it moves like having different DPI settings for x and y axis. The only solution is to select a DPI setting from the top buttons.
I don't get issue 1 with my Ouroboros personally. Switching from wired to wireless is relatively painless, altho it does take about 20 secs for Windows to "install drivers" (even though you'd think they're the same drivers).
Issue 3 is exactly as you describe it for me also. I have an additional issue since I use S3 sleep on my PC, where, upon waking the system, the mouse doesn't work really atl all for up to a minute.
I have had just as little useful help as you from Razer, and have long since given up. If they ever come out with a fix that actually works, please post it here!
I'm having the exact 3 issues and have raised it to Razer support but have so far gotten no reply. In the meantime, I have fixed Issue 1. Surprisingly, all I had to do was turn off Surface Calibration, which is weird since I have a Razer Goliathus and you'd think the mouse should be compatible with it. If you "fix" issue 1 this way, then you can forget about issue 2 even though it sucks not being able to use one of the mouse's features.
Issue 3, however, is a different beast. I haven't found an answer to it yet, although at least it can be remedied by the DPI switching you described.
I'm really happy with the mouse IF and WHEN it works perfectly. All in all, though, it has been hell.
EDIT: I do have an issue number 4 though. At any random moment, the button configurations on the mouse don't work. I have the right side buttons disabled since I don't need them, but after a while they act like the left side buttons (for example, back and forward in browsers). The same thing happens if I, say, assign it something else (like a keyboard press). The only thing that fixes this for me is a complete PC reboot. 🙁
