Immortalbasque :
vflow said:
Same issues on my new Ouroboros, bought 13th (hmm!) of February 2013. Here is part of my conn with Razer Support:
"OS Win 7 Ultimate x64
1. When changing from wired to wireless mode mouse freezes. Only solution to restore the mouse functionality is to log off-log on which means the game session is compromised.
2. I am using Razer Goliathus Control Edition mouse pad. Despite the calibration for this pad it seems that Synapse cannot remember the settings so each time I start the computer I find different settings under Calibration tab.
3.After mouse stand-by mode on wake up, it becomes unusable, it moves like having different DPI settings for x and y axis. The only solution is to select a DPI setting from the top buttons.
Hey Guys,
same issues as you... i'm on my second mouse and still no luck, thought id be the one to tell you that Razer is working on fixing the issue.
I've been talking to them since January and I had my issue escalated. Finally I had someone who was able to help me out and not give me generic answer like try it on another computer. Razer have now come up with a new firmware update for the mouse.
I must admit it doesn't solve all the issues but it certainly fixes problems with the slow DPI clutch and the mouse being laggy.
FIXED
FIXED I am using the same mouse pad and i no longer have to do that.
FIXED This was my biggest problem with the mouse and it has been resolved.
Anyway here is a direct link to the update but make sure before the update is completed that you get another mouse if you want to keep control of your computer as the mouse turns off. AND You must connect the mouse via the cable and not wirelessly prior to running the update.
DIRECT LINK- http://dl.razerzone.com/drivers/Ouroboros/win/Razer_Ouroboros_FirmwareUpdater_v1.03.02.exe
Also a Synapse update came out last night which may help you guys.
I've told Razer about the update doesn't solve all issues and i am waiting for a reply, I'll keep you posted on any updates...
nitrium :
Bad_Horse :
So, just to confirm, there are no crucial issues happening with the new firmware update? By crucial issues I mean anything that would make my game experience suffer - sudden changes within a game, random occurences etc.
No no issues for me - i.e. it doesn't break anything new and fixed a number of issues (no where near all of them though). However, it looks like Razer has pulled the update:
http://drivers.razersupport.com//index.php?_m=downloads&_a=view&parentcategoryid=360&pcid=244&nav=0,76,244
As you can see, there are now no firmware updates for the Ouroboros! Not sure why Razer has done this, since the update was a definite step in the right direction.
how do fix this number 1 problem?I still cant figure how to solve this one..
fortunately I dont have any problem with dpi..i just keep asking razer team and they just said to RMA,actually it so annoying..
