Hi! Do you know if there's a way to assign the audio volume and stereo balance controls to the arrow keys on a laptop?
I'm an old guy who has to spend the better part of each day in bed due to worsening debilitating chronic ailments.
So I've increasingly pressed my refurbished Dell Latitude 3330 laptop into service as a substitute for my old-school stereo system with it's receiver, turntable, CD player and cassette deck.
Instead I just have my music on my laptop which sits on a little shelf right next to my bed on the left side.
One problem with this setup is that it takes two hands to make a simple volume adjustment; the left hand to press and hold the Fn key and the right hand to press either the F11 or F12 key to turn the volume down or up.
But that's comparatively easy compared to adjusting the left/right stereo balance which requires:
My laptop has a set of four arrow keys in the lower right hand corner of the keyboard like this:
Arrow Keys on Delbert by Will Anderson, on Flickr
I seldom use those keys, so I'd like to try to remap them so that the up and down arrows would adjust the volume level up and down, and so that the left and right arrows would adjust the stereo balance.
I'd appreciate some help figuring out how to do this.
- Moving the mouse pointer to the speaker icon in the system tray,
- Right clicking
- Moving the mouse pointer to "Open Sound settings"
- Left Clicking
- Moving the mouse pointer to "Device Properties"
- Right clicking
- Moving the mouse pointer to the blue marker on either the L or R "Balance" slider
- Pressing and holding the Left mouse button while moving the mouse pointer left or right
