G
Guest
Guest
neo_navy :
To - Realtek HD Audie Manager
- Audio On / Off
- Connector Setting
- Select Disable front panel jack detection...
That should do the trick... It worked for me...
Cheers,
Gab.
- Audio On / Off
- Connector Setting
Cheers,
Gab.
Thank you sooooooooo much for this advice. I was having the same problem and I tried exactly what you said. It worked. My sounds are Great!!!! =)
Was Hopeless in NJ, but not anymore.
