reboot command for remote machine
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.work_remotely (More info?)
If I have missed this answer, sorry. I use RDC to install
software on workstations in our network. Does anyone know
how to reboot the remote machine. I tried to add the
shutdown button in statup but its not available,ctrl-alt
delete brings up the local window with shutdown button
When you click on the remote machine's start button do
you see an ICON that says WINDOWS SECURITY. If so click
it. It emulates pressing the CTRL-ALT-DELETE keys on the
remote machine.
>-----Original Message-----
You can do a <Ctrl><Alt><End> and bring up the remote Task Manager. Then select the "Shutdown" menu
at the top of the Task Manager window and select the desired action. You can also use the "tsshutdn"
or "shutdown" commands from the command line. Open "Help and Support" and search on each for the
proper syntax.
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com
This posting is provided "AS IS" with no warranties, and confers no rights...
"samk" <anonymous@discussions.microsoft.com> wrote in message
news:1a9de01c44f05$0a2f4f80$a301280a@phx.gbl...
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.701 / Virus Database: 458 - Release Date: 6/7/2004
I haven't seen that Icon on the start menu of any RDC connection
I have made.
Do you know how to enable it?
> remote machine.
It doesn't always appear.. Try CTRL-ALT-END - this does the same
thing as Ctrl-Alt-Del in a Remote Desktop session.
Jeffrey Randow (Windows Networking & Smart Display MVP)
jeffreyr-support@remotenetworktechnology.com
Please post all responses to the newsgroups for the benefit
of all USENET users. Messages sent via email may or may not
be answered depending on time availability....
Remote Networking Technology Support Site -
http://www.remotenetworktechnology.com
Windows XP Expert Zone - http://www.microsoft.com/windowsxp/expertzone
On Fri, 25 Jun 2004 08:41:54 -0700, T. Barnes
>I have made.
>> remote machine.
