Recommendation - mostly 2D
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.matrox (More info?)
Building a new system around an Asus P4C800E. It will mostly be used for 2D
work, ranging from text to Photoshop, to the occasional (??) game. On most
of the systems I've built to date I've used Matrox boards, largely for the
high-quality 2D performance and general stability. However, on recent
systems the Matrox and Asus boards do not necessarily play nicely together
in certain graphics modes.
Bottom line - for general purpose use, but very high quality and stability
2D (NOT high-performance, high-end gaming), what board(s) out there would
you all recommend? I'm leaning toward considering an Asus board for
possibly better compatibility. For this system, I'd like to keep the price
to a max of about $150 (Web price, OEM or retail). Any recommendations
appreciated.
Thanks.
G
Guest
Guest
I've used,
Matrox G400
Voodoo5
Nvidia 5200
ATI 9100
and now an ATI 9600 PRO AIW.
So I would say to get an ATI 9600 PRO or even an 9600 XT
"ke" <elliottk@earthlink.net> wrote in message
news:prXdc.3279$zj3.1523@newsread3.news.atl.earthlink.net...
2D
price
> appreciated.
> Thanks.
JohnS
314
2D
Doesn't sound worth doing to me. If you are not a gamer,
why go to an expensive mobo? I've got Gigabyte integrated
mobos ( run around $45 to $65 ) that are really stable running
AutoCAD, Solidworks, and Office, and they are holding up
well. The Intel Application Accelerator that comes with those
boards, make booting and loading of apps quick, and the
integrated graphics runs most OpenGL games very well. They
are good little workhorses, and very affordable. A fully
integrated board like that, has been tested completely, and
tends to be bug free. On the ones I'm using, I can install
Linux Redhat 9 without a hitch and all functions working
and stable. Now that is a test of reliability if there ever was
one, because RH 9 is a joke regards compatibility with
most hardware. I've had dual boot with WinXP up and
running for months without RH crashing and burning.
Think about it :)
johns
G
Guest
Guest
>> used for 2D work, ranging from text to Photoshop, to the occasional
>> (??) game.
One word: Photoshop.
Intel Application Accelerator is just a replacement ATA driver with extra
buffer cache -- you can do the same with third party utilities, or even
better[1] by setting Windows to do aggressive ("server") caching. Extra
RAM-eaters is NOT what you want if you run Photoshop, cause you want all the
memory to be available to PS to do its own caching.
Oh, and besides that, IAA is incompatible with a whole bunch of programs,
including (but not limited to) Veritas/Stomp BackupMyPC, various packet
writing software for CDs/DVDs and ejectable harddrives.
[1]: For one thing, Windows FS caching will release the memory when it's
needed for other things.
Regards,
*Art
G
Guest
Guest
On Mon, 12 Apr 2004 09:42:43 -0400, "Arthur Hagen"
| >> (??) game.
IAA is also incompatible with Intel's 865 and 875 series of chipsets.
Larc
§§§ - Change planet to earth to reply by email - §§§
G
Guest
Guest
"Larc" <larc-news@jupiterlink.net> wrote in message
news:uqel70h7popkjjktvoasj7tulo1tcbt460@4ax.com...
> | >> (??) game.
extra
all the
programs,
Not true.
G
Guest
Guest
> Not true.
You can't just make a statement like "Not true" without qualifying it -- you
make yourself look like an idiot.
For i865/875 with a plain ICH5, or with an ICH5R without running RAID,
there's no compatible IAA.
There's something called "Intel Application Accelerator Raid Edition" for
i865/875+ICH5R with RAID 0 or 1, but that's just Intel's RAID driver with a
new name, and has nothing to do with IAA as discussed here.
*Art
G
Guest
Guest
Get a P650 and do all the stuff that Matrox's TS says and then it works for
2D. I'm running two P4C800E Deluxes(1016)(XP, W2K3) with P650s.
2D
price
> appreciated.
> Thanks.
G
Guest
Guest
On Tue, 13 Apr 2004 02:36:19 GMT, "Ron Reaugh"
| Not true.
You can check at Intel for yourself:
http://www.intel.com/support/chipsets/IAA/sb/CS-009312.htm
Included on this page listing chipsets IAA supports is the following
statement:
Note: The Intel Application Accelerator is not compatible with the
Intel® 875P, 865G/P/PE, 852/855 GM/GME, 855MP, 848P, 815EM chipset,
the Intel® 440 chipset family, or any earlier Intel chipsets.
Larc
G
Guest
Guest
Kind of where I was leaning (Matrox 650). But I wanted to get some input to
assess whether it made any sense to consider an Asus video board, in the
(unfounded) hope that there would be more seamless compatibility with the
Asus P4C800. I've been using older Matrox boards (400, 450, 550) with Asus
mobos, with generally solid results, but recently built a system around a
P4C533 and a Matrox 550 that experienced a hard crash (full power down)
whenever WMP 9 was used to view a video. (realPlayer handles the same video
with no issues). Never solved the issue, regardless of drivers used, etc.
This and other little annoyances led me to look at options other than the
Matrox 650 before plunking down the $.
Thanks for the input.
"Ron Reaugh" <ron-reaugh@worldnet.att.net> wrote in message
news:0pIec.13486$K_.431473@bgtnsc05-news.ops.worldnet.att.net...
for
for
> 2D
most
the
together
stability
would
> price
> > appreciated.
> > Thanks.
G
Guest
Guest
Hi Ke,
I have the P4C800E Deluxe (i think that is what it is :) ) with the
Parhelia and I am very pleased with it, which I use for Digital Darkroom
working on DSLR files.
I can't think of any problems and I have had this for some time now.
Good luck
Henrik
2D
price
> appreciated.
> Thanks.
G
Guest
Guest
"ke" wrote in message...
> input to assess whether it made any sense to consider an Asus video
> board, in the (unfounded) hope that there would be more seamless
> compatibility with the Asus P4C800.
What makes you think there's some sort of chronic incompatibility between
Matrox cards (in general) and the board you're considering? It would appear
that your previous experience is overwhelmingly positive, no?
At end of day the best board for your chosen application would appear to be
the Millennium P650, and there's no reason to expect any compatibility
issues with it.
Richard Hopkins
Cardiff, Wales, United Kingdom
(replace .nospam with .com in reply address)
The UK's leading technology reseller www.dabs.com
Get the most out of your digital photos www.dabsxpose.com
G
Guest
Guest
Historically my experience with Matrox boards has been positive, but recent
problems unique to the combination of a G550 and an Asus P4B533 have caused
me to consider other video options for a new system based on the Asus
P4C800E. While the problems experienced (system crashes caused by certain
video calls) can easily be worked around by an experienced user, since I
need to supply this system to non-technically oriented customer(s) who would
understandably be apoplectic if the system does not function flawlessly in
any and all applications they are likely to run.
Hence the interest in trying to ensure the video element of the system is
relatively bulletproof. While the end user is likely to run his common
applications day in and day out for weeks or months at a time with the
Asus-Matrox combo without a hiccup, I'd like to avoid any callbacks due to
system crashes when the end user happens to open a video using WMP 9 (or
whatever other application may access the same video call(s) that cause a
system crash in WMP9).
"Richard Hopkins" <richh@dsl.popex.co.uk> wrote in message
news:407ef2ef$0$17912$cc9e4d1f@news-text.dial.pipex.com...
appear
be
> issues with it.
> Richard Hopkins
robin
246
On Wed, 14 Apr 2004 16:05:57 +0800, "Henrik Tived"
<tived@iinet.net.au> wrote:
>Hi Ke,
>Good luck
>Henrik
>2D
>price
>> appreciated.
>> Thanks.
I'm using a G400 Max and if you're interested in 2D, that's about all
you'll need. Great 2D and I have no problem playing dvds, etc.
G
Guest
Guest
I'm not sure they're still available new, but Newegg has the G450 for
$89 including shipping. I just bought another one.
Larc
