alxhr22 Nov 12, 2022 6 0 10 Nov 12, 2022 #1 This monitor presents rectangle artifacts in photos, movies, games and videos, especially in dark areas. How to fix it?
Fix_that_Glitch Judicious Mar 31, 2019 7,073 815 32,940 Nov 12, 2022 #2 What is your pc setup? Upvote 0 Downvote
Fix_that_Glitch Judicious Mar 31, 2019 7,073 815 32,940 Nov 12, 2022 #4 Can you post your 3d setting in the control panel? Upvote 0 Downvote
alxhr22 Nov 12, 2022 6 0 10 Nov 12, 2022 #5 Fix_that_Glitch said: What is your pc setup? Click to expand... Processor: Intel(R) Core(TM) i5-10400F CPU @ 2.90GHz 2.90 GHz RAM: 16.0 GB (15.9 GB usable) GPU: RTX 3060 12 Gb GDDR6 Motherboard - Gigabyte FCLGA1200 But is not from this PC. I tested monitor on other PC and laptop and I have same issues with rectangle artifacts. Upvote 0 Downvote
Fix_that_Glitch Judicious Mar 31, 2019 7,073 815 32,940 Nov 13, 2022 #7 What resolution are you using and what monitor? Did this just start happening? Upvote 0 Downvote
alxhr22 Nov 12, 2022 6 0 10 Nov 13, 2022 #8 Fix_that_Glitch said: What resolution are you using and what monitor? Did this just start happening? Click to expand... 3840 x 2160 It had artifacts since I bought it, but only in movies on platforms like Netflix or HBO Max. But for a while it has artifacts both in games. Upvote 0 Downvote
