[SOLVED] Remote access/control a phone with a fuzzy screen?
supermanu15
308
My Xiaomi Mi4i's screen is busted, is showing fuzzy images and lots of orange to white lines so I can't use it, so I bought another Android phone, my question is how can I export my SMS messages from there to the new phone? What app should I use? I can't do Vysor(the chrome plugin) that allows me to remote into it because the screen is fuzzy so I can't enable USB debugging. Are there any free apps out there?
sms backup and restore. Run the app, it exports to a XML file then move that to you new phone and import using the same app.
You can't just remote into it. You can try using a OTG Cable and either plug ina mouse or a USB hub and plug in a mouse/usb stick to copy the files off or you can try installing teamviewer on the phone with the mouse and then control it on the PC.
thing is, i just can't :/
the screen is fuzzy and i cannot get to install some apps in there :/
one of the reasons i am handing this over is that this is a company phone, once i resign i would eventually hand it back which is why i didnt invest in it too much
