(Remote Desktop) Auto reconnect local after remote discone..
saran
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hello. My main system run XP Pro (SP2), and I make a lot of use of the
Remote Destop feature.
After I disconnect my remote session, on the local system it's at the
login prompt [1] and I'm wondering if it's possible to make it auto
login after the remote session disconencts, much like the system auto
logs in upon boot.
Thank for any help.
[1]
I don't use the welcome screen; why is the welcome screen even on by
default in Pro?!
Reboot the system on disconnect. start/run, type : shutdown /r
I recommend you choose a password, but you don't have to. o to start/run, and type 'control userpasswords2' , Uncheck the password
option, and follow the wizard. This will log you on without asking for the password on reboot.
Mark L. Ferguson
FAQ for Windows Antispy http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
"Saran" <none@nospam> wrote in message news:eJ4fvC$hFHA.2560@TK2MSFTNGP10.phx.gbl...
> logs in upon boot.
> Thank for any help.
> [1]
> default in Pro?!
