Remote Procedure Call??
Adam
343
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hi, I earlier acessed a UK web site (at a university) from home and tried to
access a link within the site - a short time after the page started loading
I got a message saying "Remote Procedure Call had failed and NT was shutting
down in 60 seconds" - I then had to wait a minute until, sure enough, my PC
re-booted. Was this a problem at my end, or was it related to the
university's server? I am running XP Pro SP2. After re-booting the page in
question loaded no problem.
Thanks.
You have the Blaster Virus. Read here :
http://www.microsoft.com/security/incident/blast.mspx
"Adam" <adam@nospam.co.uk> wrote in message
news:d38bas$p48$1@sparta.btinternet.com...
> to access a link within the site - a short time after the page started
> loading I got a message saying "Remote Procedure Call had failed and NT
> was shutting down in 60 seconds" - I then had to wait a minute until, sure
> enough, my PC re-booted. Was this a problem at my end, or was it related
> to the university's server? I am running XP Pro SP2. After re-booting the
> page in question loaded no problem.
> Thanks.
Hey i had this problem, it seems to be called the W32.blaster.worm ,
this page should help
http://forum.theispguide.com/ftopic135-0-asc-60.html
also when you get that message hit
start, run then type: SERVICES.MSC /S
then In the right pane, locate the Remote Procedure Call (RPC) service
Right-click the Remote Procedure Call (RPC) service, and then click
Properties.
Click the Recovery tab.
Using the drop-down lists, change First failure, Second failure, and
Subsequent failures to "Restart the Service."
Click Apply, and then click OK.
You should be ok then!! gd luck!!
> tried to
> loading
> shutting
> my PC
> in
> Thanks.
buffy2k5
