Hi,
I’m looking for advice on replacing the failed LG GTA0N optical disk drive in my Dell T7910 workstation.
What would be a reliable drive to replace my existing, but failed LG GTA0N optical disk drive? This drive seems to have been discontinued. Besides, it failed after very little use. My current optical drive configuration is:
PC: Dell T7910 Workstation
O/S: Windows 10 Professional
Current (broken) optical disk drive: LG Super-Multi 8x DVD Rewriter GTA0N. The drive dimensions are (WxHxD): 5.0" x 0.5" x 5.0"
Optical disk drive caddy: 3.5” Dell OEM 1B31PR100-600-G (https://www.amazon.com/1B31PR100-600-G-1B31PR200-600-G-Genuine-Dell-Precision/dp/B078KGX3GL/ref=cm_cr_arp_d_product_top?ie=UTF8). The caddy dimensions are (WxHxD): 7” x 4.5” x 1”. Are there any other caddies that would fit into the T7910 that could take different sized optical drives than the GTA0N?
I would be grateful for any recommendations of reliable optical disk drives that would fit my existing caddy. So far the only one I have been able to find is the LG Electronics Slim DVD Super Multi Optical Drive (GTC0N) on Amazon. Given my ill fortune with my failed LG GTA0N, I'm now wary of LG drives. Does anyone have any experience of the GTC0N?
My thanks in advance for your comments and advice.
