Request assistance with XP Home problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
OK! This may be something someone has previously described
before, but I can't resolve it. I am running Windows XP and
have all the updates. When I open a folder, I can not get
the stupid software to save my preferred settings for the
folder. I desire to have the address bar appear in the
header of the folder.
I have opened the "View" menu a hundred times, click
"Toolbars", and click "Address Bar" so that the check mark
appears. I then click "Lock the toolbar" so that the check
mark appears. I then open the "Tools" menu, click the
"Folder Options" tab, click the "View" tab, and click "Apply
to All Folders". Then I click "Ok", close everything,
reboot, and I'm back to square one with no address bar
visible in the folders.
Does anyone understand why this happens? Can anyone propose
a solution?
Many thanks for your assistance. I suspect that it
something simple, but I am at a loss as to how to resolve
the dilemma.
Please email me at nospam1953@bellsouth.net.
Although i don't know exactly why it would be doing this, i think it
wouldn't be a bad idea to create another account with the same privledges
(which must be administrator to make account). Then see if it works for them
If it does than make a backup of ur user docs and settings and delete ur
user, then re-add your user
I can't and won't guarrentee this to work but it would be what i'd do
Jayso
Please reply to this email so I know if i'm right :)
Good in Home Networking, XP Home based problems, and Pro based Problems
Add my email to MSN Messenger if u wish
jayso_chinnery@spamfreehotmail.com.au (remove spamfree)
"Regnad Kcin" <NickDanger@ThirdEye.net> wrote in message
news:iK5Ve.35983$1g2.22298@fe05.lga...
> a solution?
> the dilemma.
