V valrog Distinguished Dec 27, 2012 224 2 18,685 Aug 19, 2019 #1 Im not sure where exactly to make this thread. So my motherboard doesnt have an rgb header. and the led strips that i have lying around require an rgb header from the motherboard. is there a way to use the led strips still?
Aeacus Titan Mar 21, 2015 14,164 2,634 84,890 Aug 24, 2019 #2 Well, there are few options: 1. Akasa Vegas control panel which would sit in your ODD bay and you'd also need 5.25" to 3.5" frame (unless your PC case has dedicated external 3.5" bay), specs: http://www.akasa.com.tw/update.php?...ing&type_sub=RGB LED Lighting&model=AK-RLD-01 2. Or if you prefer your RGB hub to be PCI-E card, then Akasa Vegas control card, specs: http://www.akasa.com.tw/update.php?...ing&type_sub=RGB LED Lighting&model=AK-RLD-02 Upvote 0 Downvote
