[SOLVED] RGB LED STRIPS
valrog
224
im not sure what topic to ask this on sorry if this is the wrong thread.
I have some extra led strips that i want to use on build but this build has a budget motherboard (literally only has 2 fan headers, cpu and sys lol). the ends of the rgb cables are i think 3/4pin crj (i think thats whats its called?)
so question is how do u guys go about using these rgb cables if ur motherboard doesnt have any rgb headers?
And you need to buy the RGB controller. And make sure you get the right one for your rgb strip that should be either the addressable rgb one ( +5V) or the regular rgb (+12), because you can't mess them up.
