Question RGB Strips won't work.. ( Z390 Aorus Pro Wifi )
Alex_220
14
I recently bought the RGB 200PRO led strips from DeepCool.
I tried installing them into my Z390 Aorus Pro Wifi, using the 3 pin VDG connectors but they won't
Turn on at all..
The led strips came with two different adapters (one with 4 "pins" except one of them is sealed off that says 5v D GND
And the other one just says VDG but it only has 3 pins and i couldn't find any connector for rgb with only 3 pins.
Do i need drivers or something? Are the strips not working or is it my motherboard?
  • 2 x digital LED strip headers
  • 2 x digital LED strip power select jumpers
  • 2 x RGB LED strip headers
Motherboard also comes with one digital LED strip adapter cable. See page 18-19 of downloadable manual.
I tried using both the adapter cables (The one that came with the rgb strips and the one that came with the motherboard) but neither of them worked.
also tried both digital led headers but they didn´t light up at all
