Question RTX 2060 Low FPS
Apr 2, 2019
So a few weeks ago I got my self some new pc parts to upgrade my pc. Within those parts was a Geforce RTX 2060 Asus Rog Strix advanced 6GB. I installed everything, there were good fps in game, then like a week past and my frames dropped big time.
CSGO went from 200 -400 fps to 80 to 100 fps
LoL went from 200 - 350 fps to 60 - 160 fps
I googled if there was a solution, I ended up uninstalling the GPU drivers with DDU and then doing a clean install of the drivers. Still with that been done with low to medium setting in both games the fps were the same. Now IDK what to do, ive optimized the GPU within the Nvidia Control Panel, but nothing is happening. I downloaded Asus Tweak II program and set it to boost option and i just got a tiny boost, These are my pc specs:
  • Geforce RTX 2060 Asus Rog Strix Advanced 6GB
  • Ryzen 5 2600x
  • 16GB RAM 3000mhz
  • two kingston SSD one 480GB and the other 120GB
  • 1TB Hard Drive
  • Windows 10 pro 64 bits
if anyone knows something please help, IDK what to do!!
Make sure you downloaded the specific driver for the 2060. In the nvidia control panel and go to “change resolution”, make sure everything reaches your monitors specs. When in game try play around with your display settings and change window format like from full screen to borderless to see if that does anything.
