Hello guys this will be my first post here, some of you may find this ridiculous but i'm hoping it can work.
Basically im going to buy this computer:
http://tinyurl.com/c9fjx3j
and this GPU:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=356682&csid=_61
In the computer it has a 500 Watt PSU, but there is only ONE 4-pin molex avaliable, I plan to use this item to
convert the 1x 4-pin molex into 2x 4-pin molex
http://www.microbarn.com/itemimages/ada-powy.jpg
and then I intend to use this to make it into a 6 pin PCI-E
http://i01.i.aliimg.com/photo/v0/489274451/6_Pin_PCI_E_to_2_X.jpg
Will this work? Or will the GPU be under powered? Thanks!
Heres some of the power info on the card I found:
Thermal & Power
Power Supply Requirements --- 400 Watt Power Supply
Power Connectors --- (1) PCI-E 6-pin Power Connector
Maximum Graphics Card Power --- 116 Watts
Maximum GPU Temperature --- 100 C
Maximum Operating Temperature --- 100 C
and this GPU:
Thermal & Power
