ive been having this issue for around a month or two now, I can start playing a game, DayZ, Battlefield, PUBG for example then after about 10-15 mins of playing the GPU usage will start jumping all over the place and my game will start stuttering, the GPU temp only reaches around 75C . i can however restart my PC and it fixes the problem ( for about 10 mins) then it does the same thing... I've tried everything to fix it including
- PC is plugged straight into wall outlet not a faulty power strip
-Moved OS and AMD software to a Solid State Drive
Im starting to think that this could be 1 to 2 things.. My power supply could be going bad because GPU wattage in game fluctuates from 105W (thats when its running butter smooth) to 10-15-30ish Watts during Stutter increments. keep in mind i get butter smooth FPS when its NOT stuttering, OR my Graphics Card could just be dying for some strange reason. This is what i havent tried yet..
Im really hoping that this is a Software or windows 10 problem, This is so frustrating and ive been racking my head trying to figure out what the problem is... Any help would be greatly appreciated, oh yeah and here is my system specs
AMD RYZEN 1600 O'C to 3.7Ghz
PowerColor Red Dragon RX 480 4GB
8GB Ripjaws V 2400MHZ ram OC'ed to 3200MHZ
Antec 620W HCG PSU
MSI b350 pro gaming Motherboard
- Uninstalled drivers using DDU and fresh updated to latest driver (helped some but nowhere near enough to call it a fix)
- Flashed Vbios (once again it helped some but not enough)
- Reinstalled windows ( didnt help at all)
- Re seating GPU
- Testing GPU in different build
- Trying a different GPU in my build
Antec 620W HCG PSU
