Depends on the price, your budget, & the games:
-- if you're solely concerned with the new DOOM, get the RX 480 (it beats the GTX 1060 by about 18%)
-- if they're the same price, or the 1060 is only 10% more than the 480, then get the GTX 1060 (it averages about 10-11% better performance than the RX 480)
-- if the GTX 1060 is more than 10% higher in price compared to the RX 480, then get the RX 480, as you'll get better performance-per-dollar (plus it's the current selection from Tom's over the 1060, http://www.tomshardware.com/reviews/best-gpus,4380.html)
