Hello. I have problems with RX 580 after I install drivers. Without drivers it works fine but it can't run any game at more than few fps. The problems are:
-Small light blue squares appear on the screwn, mostly on white backgrounds
-Sometimes screen goes off than back on, same way it happans when you unplug and plug HDMI cable.
What I tried:
I have tried many drivers and new F81 bios (it came with F80).
I tried drivers from AMD and Gigabyte site.(20.1.3(latest),19.9.2(recommended),17.8.1(the one from gigabyte website)).
I have tried reinstalling windows 10 and it didn't help. I am curently trying windows 7 but I have to update it to be able to install derivers. My windows 10 is updated and ther are no more updates. Artefacts do not show in bios. I have tried other PCIE slot (both are 2.0 X16) bith with no success. Tried other 8pin connector and it's the same. And I forgot to mention that gpu usage was stuck at max while memory usage was normal.
Specs:
Windows 10 PRO x64 ver.1903
CPU: Intel Xeon E3-1220 3.1GHz
GPU:AORUS RX 580 8gb Rev. 1.1
MOBO: Asus P8B-E/4L (PCIE2.0 X16)
PSU: Fujitsu 760w
RAM: 8GB (2x4GB) 1333MHz SAMSUNG ECC
SSD: Kingston A400 240GB
HDD: WD Green 1TB 5400RPM
Monitor: Samsung SyncMaster BX2231 1080p60hz
What I tried:
Specs:
PSU: Fujitsu 760w
