Hello,
My CPU is a Ryzen 3700x mounted on an MSI MPG X570 Gaming Plus motherboard and I am slightly concerned about the temperature issue of this CPU.
The temperature values in AMD Ryzen Master only with the Firefox browser are around 40-45 degrees and I do not know if that is normal for this cpu, considering that it has an offset type undervolting of -0.1500v.
The pc itself is less than a year old, and I did this undervolt because the temperatures were even higher than stock. My question in summary is if I should be concerned about these numbers or should I leave it as it is?
Maybe I should adjust the voltage better or make a slightly higher offset for security reasons, the truth is that I don't know for sure.
Here, I leave a screenshot of Ryzen Master with those values and my BIOS with the aforementioned offset.
Thank you.
Greetings to all.
PS: The built-in cooler is not the stock one, but a Cooler Master Hyper 212 RGB Edition.
Thank you.
Greetings to all.
