Hello, I've just build a new pc recently and decided to check my temperatures. I was surprised how high it went and that it bounces up and down quite a lot. My temperature while idle go from 40-55 degrees and while gaming (R6 Siege on max) they go from 75-85 or even higher (Assassin's Creed Origins). I tried instaling latest chip drivers and BIOS drivers, I've also reapplied thermal paste and made sure stock cooler is mounted correctly. My room temperature is like 20-21 degrees, I tried opening the windows and case for better air flow with no differance.
CPU: ryzen 5 3600
GPU: gigabyte geforce gtx 1660 super
MBO: msi b450 gaming plus max
RAM: corsair 16gb ddr4 pc3000 cl16
PSU: be quiet! pure power 11 600W 80+ gold
Originally I wanted to use my old cooler master 212 for the setup but I don't have the am4 bracket so I had to go with the stock am4 cpu cooler. I do plan to get an aftermarket cooler but for the time being i'm stuck with the stock.
CPU: ryzen 5 3600
