My CPU clock speed been jumping from 3600mhz to 4800mhz like every second and the temperature been 50c'
How can I fix this
How can I fix this
Fix what? there's nothing wrong. It's perfectly normal with good cooling.My CPU clock speed been jumping from 3600mhz to 4800mhz like every second and the temperature been 50c'
How can I fix this
It was not like this when I build my pc back in 2021 it only started acting like that recentlyFix what? there's nothing wrong. It's perfectly normal with good cooling.
There's not much to go on here. But uninstalling RyzenMaster is a logical first step: it seems obvious you don't want to benefit from the "overclocking" it's meant for and it's known to adversely affect performance under certain conditions. If you're looking for a good monitoring program the best one for Ryzen is HWInfo64.It was not like this when I build my pc back in 2021 it only started acting like that recently
I had more performance before my CPU started acting weird and some games I play now keep crashing since it started acting weird
I try to reset settings in bios and AMD Ryzen Master settings it didn't change anything
