For one reason or another, the entire network went down in my area for several hours...
One more thing. I was also thinking about just going with a dark rock pro 4 instead of an aio. Would you still recommend an aio over a high end air cooler for this chip because of its thermal behavior?
You can choose whichever type you wish - I'm not against having options. They both have their pro and cons.
I was trying to warn you that an AIO wouldn't offer a 'knock-your-socks-off' difference over air, especially not against the 5800X's little... 'quirk'.
A)Large single tower, dual tower, 280mm AIO.
I find these types to be the best overall, thanks to their use of 140mm fans, thus they offer a better balance of performance to noise profile, which can cause them to match or beat coolers larger than them - which are few, anyways...
By large single tower, for example: Thermalright's Macho Rev. C or Noctua NH-U14S.
The MA410M, underneath that 'armor', is more of a medium size tower cooler.
B)360mm or larger AIO.
These lack flexibility due to tubing length, and being huge. You are more or less stuck with mounting the radiator at the top of the chassis - not that it's necessarily a bad thing, but it could create compatibility issues with future chassis picks.
A front mount fits, you say? Well, the 'drip-drip', or running water noises that inevitably appear from mounting it that way WILL make you move it to the top eventually - and if it doesn't fit up there, then you have to get rid of it...
Kind of a waste, when the unit isn't even broken.
C)240mm AIO.
Just straight up skip these if you can fit any of the types from point A. 240mm just don't have enough going for them in comparison. Heck, I think even the less flexible 360mm and 420mm are better options...
People often eat them up due to pricing, and 'because liquid'.
