Hello community!
I received the mission of buying parts and putting together a computer for a friend of the family.
SPECS;
Core i7 950(3.06G,L2:4x256KB,L3:8M, rev.D0,130W)
ASUS Sabertooth X58
6GB of Corsair XMS3 3x2GB
GeForce GTX 570
Corsair GS700w power supply
Cooler Master CM 690 II
Western Digital 500GB SATA
Everything is in there nice and snug, cables have been connected and hidden as best as possible.
Currently the machine does not have an operating system, because the DVD drive did not arrive yet.
PROBLEM;
When I turn the PC on, it boots nice and tight, then after 5 seconds, it turns off. Now this would be a standard issue of not enough power, or dysfunctional/misplaced RAM, but here is the weird part. After shutting down, it turns on again by itself, runs for 5 seconds, turns off one more time, turns back on one more time by itself, and THEN it runs as it is supposed to.
So I press the button, it turns on, shuts off, turns on, shuts off, turns on and runs properly all by itself.
I am, however, able to access to BIOS when it finally does keep running, and in the BIOS it says it only registers 4GBs of RAM.
There are six slots on the MOBO for RAM. [+] is an inserted RAM stick, [] is an empty.
Here is how they are placed.
[+][] [+][] [+][] - which should be the A1 B1 and C1 as shown in the MOBO manual.
If one stick of RAM is removed, the machine boots properly the first time it turns on.
THEORIES;
All power cables are firmly placed, everything is double-checked, I am ruling pwsupply out.
As mentioned, Windows is not installed, could be it?
Perhaps an outdated BIOS/Incorrect voltage settings? Even though you really shouldn't encounter problems with incorrect voltage, as the machine will be running factory settings.
Any ideas? Switching the RAM sticks around didn't help much, perhaps using the right side of the RAM slots will do anything?
Appreciate your help
SPECS;
ASUS Sabertooth X58
GeForce GTX 570
PROBLEM;
THEORIES;
