Question Samsung 990 Pro running at pcie 4.0 x2 instead of x4
Feb 15, 2025
4
Hi,
I have a problemm, my Samsung 990 pro 1tb doesnt want to run in pcie 4.0 x4, its stuck in x2 and the speeds are half of what they should be.
View: https://imgur.com/a/iJ4UM5m
I tried reseating the drive and cpu, 7C56v1J3 and 7C56v1I Bios but no change. My mobo doesnt even have m.2 options in Pcie bios settings
Msi B550 gaming plus
ryzen 5 5600x
Samsung 990 Pro 1tb
Your motherboard has 2x M.2 slots, which one have you dropped the 990 Evo into? What other devices do you have in your build?
Reflash to the beta version BIOS, then clear the CMOS. In order to do the latter, you disconnect from the wall and display, then remove the CMOS battery, then press and hold down the power button for 30secs to drain any residual power, then reseat the battery after 30mins.
Drive is under the cpu where it should be, i already reflashed bios and cleared cmos a few times to be sure, even took apart a whole build and put everything in again to be sure, m.2 slot pins also look good
