So I've had this ssd for a couple of months now but for the past month or two its eating my nerves, constantly crashed my windows (ssd was not used for the windows installation), I reinstalled but this time I installed windows on that ssd, now whenever it happens instead of crashing it freezes EVERYTHING, cannot do anything else except move my mouse, literally nothing else.
Finally I know what happens but not why. So the SSD randomly (usually when I play a game, but did it once even when windows was idling) goes to 100% usage but I have Task Manager on my second monitor to watch for when it happens and it says 0 read/write speed, so the ssd is 100% without actually being used ?!?
Things I tried with no success:
Updated firmware via Samsung Magician;
Updated to official Driver from samsung's website version 3.3
Did all kinds of scans and SMART checks via Samsung Magician (no problems were reported)
Just to be more clear in one sentance: Windows is freezing ONLY when the NVMe SSD goes to 100% with ZERO Read/Write speed reported.
I am desperate to find a solution, is it the ssd's fault, should I return it, or is it some weird software bug, from other forums and threads I've heard that other people that have this issue switched to windows 7 and it stopped happening but I cannot confirm this for myself.
EDIT: Ok so it seems this issue is maybe not local to the SSD, I plugged a portable HDD, and this time its done it to that drive, again that hard drive is 100% with no read/write operations, but this time I assume since its not the OS disk its not crashing windows or freezing it, although there is still some problems with some processes that are trying to access it.
Idk if its this but I've noticed that before I plugged in the HDD the ssd was the last disk at number 3 (the 4th drive), now when I plugged in the HDD the HDD itself is the last drive which is drive 4 (the 5th drive), can this be caused by some weird bug that is affecting the last disk in the system.
I used "Disk Monitor" from sysinternals, sadly it doesnt display what process is trying to do the operation but something is trying to write to the "frozen" drive with data length of 0, now this 0 may be because the disk is inaccessible and its saying 0 because of it OR this unknown process can be the problem if he is trying to write 0, but I would bet on the first case
Also I dont know if I mentioned it but im 99% sure its not a drive failure, i did all kinds of checks & tests, including Samsung Magician both short & long diagnostics, used "HD Tune" with both quick scan and normal scan on ALL disks, all of them had NO bad sectors. Also the problem with the new HDD is most likely not a hardware problem as this HDD was literally bought 2 days ago
