Hello everyone,
I recently bought a Sapphire R9 290 Tri-X (OC) and Its just a beast. But the problem is I have issues with the performance on most games. I was on Catalyst 14.4 drivers but that just made it worse so I switched to the beta 14.6 Drivers. My specs are:
Crucial MX100 SSD
LIAN LI PC-A77F (Switched from Fractal Design R4 silenced)
WD Black HDD
Crucial Ballistic-X (2x4gb of ram)
FX-8350 @ stock (Runs on the hotter side)
Sapphire R9 290 Tri-X (Problems)
ASUS Sabertooth 990FX r2.0
PLEASE NOTE THAT I AM USING A 1400x900 DISPLAY AS OF NOW, SO THESE NUMBERS SHOULD BE WAY HIGHER DUE TO THE FACT MOST BENCHMARKS DONE ONLINE ARE BENCHED AT 1920x1080
Temps are ok. CPU gets hot 55-60+ under load. fan goes crazy.
Unigine Heaven Benchmark 4.0
FPS: 111.7
Score: 2815
Min FPS: 9.2
Max FPS: 229.3
System
Platform: Windows 7 (build 7601, Service Pack 1) 64bit
CPU model: AMD FX(tm)-8350 Eight-Core Processor (4013MHz) x4
GPU model: AMD Radeon R9 200 Series 14.200.1004.0 (4095MB) x1
Settings
Render: Direct3D11
Mode: 1440x900 fullscreen
Preset Custom
Quality High
Tessellation: Normal
This guy is in 4400? is it normal?
http://www.tweaktown.com/reviews/6354/sapphire-radeon-r9-290-4gb-tri-x-oc-video-card-review-with-4k-tests-/index5.html
At ultra:
FPS: 68.7
Score: 1732
Min FPS: 8.7
Max FPS: 146.0
This guy get 100+ FPS, but he does have a better set-up. but its more GPU heavy right?
http://www.eteknix.com/sapphire-r9-290-tri-x-4gb-graphics-card-review/6/
BF3, 50-20 fps lower both multiplayer and singleplayer (more multiplayer though) then anywhere i can find, and the people testing are running at higher resolutions.
Tomb Raider is actually pretty close to what im getting. Im getting 84fps.
http://www.tweaktown.com/reviews/6354/sapphire-radeon-r9-290-4gb-tri-x-oc-video-card-review-with-4k-tests-/index10.html
I see most people online saying this card handles anything they throw at it @60fps @1920x1080 or @1920x1200, for me it varies, when i look it open landscape, 60 fps easy. When I turn around at the battlefield/action in any game (farcry 3 blood dragon, tomb raider, bf3...etc) it dips to 40-60 fps depending on the amount of explosions and ai/people.
the questions is: is it normal?
Crucial MX100 SSD
WD Black HDD
FPS: 111.7
Score: 2815
Min FPS: 9.2
Max FPS: 229.3
System
Settings
Render: Direct3D11
Preset Custom
Quality High
At ultra:
FPS: 68.7
Score: 1732
Min FPS: 8.7
Max FPS: 146.0
