Scheduled task and VB-program problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hi.
I´m running a VB program from Sheduled Tasks, the VB program is
supposed to bring up a form with information. The program works fine
when started the "normal" way but when i start it from Sheduled Tasks
it does start but it does´nt bring up the form. You can see the
program running among the processes but thats all.
Any suggestions will be gratefully noted.
Thanks.
"Ecco" <ecco@eccow.com> wrote in message
news:1126074301.731822.292260@g14g2000cwa.googlegroups.com...
Hi.
Thanks.
You might find a clue here:
Phydeaux 's post
Monday, September 05, 2005 4:31 PM
microsoft.public.windowsxp.perform_maintain
Re: Can't schedule a batch file to run in the XP Pro Scheduler
Check the path.
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:1126074301.731822.292260@g14g2000cwa.googlegroups.com,
Ecco <ecco@eccow.com> hunted and pecked:
> Hi.
> Thanks.
Hi and thanks for your input.
Unfortunately the problem still occures.
Is it possible that the task won´t run because of the user account?
I created the task logged as Administrator and as such it works, when i
log in with another account (also with admin rights) it will not work
as planned. The program, an exe file, starts but the user interface
won´t show. The program runs only as a process.
Any suggestions appreciated.
Ecco
Hi again.
The problem was that the other account didn´t have a password set.
Thanks for your help.
Regards
Ecco
Glad you figured it out. Keep having fun. 🙂
Wes
In news:1126182886.080257.297000@g49g2000cwa.googlegroups.com,
> Hi again.
> Regards
> Ecco
