[SOLVED] Scratch Disk Speed
Feb 9, 2019
26
Hello,
How fast should scratch disks be for Premiere Pro, 3D software and Photoshop? Is any SSD sufficient, or are there any recommended minimum read/write speeds?
OS and project files are on 970 EVO drives (so, pretty fast) and have 32 GB RAM.
Thanks!
Reactions: rcald2000
the difference between a fast and a slow ssd scratch drive might be measurable with the right equipment. I highly doubt you'll notice any difference. I used a 128 but it required frequent purging and i'd reccommend at least 256, particularly if you are also using it for lightroom/bridge.
Reactions: bestunta
I'm probably going for either a WD Blue 500GB or WD Green 480GB. If difference in performance as a scratch disk isn't noticeable, I guess I'll go for the Green.
Thanks!
