hey guys, today just bought a new LCD screen. havin some problem with the display.
ok. im using 2 PC connect to 1 LCD screen. using KVM switcher to switch between them...
problem is that this LCD display having some issue. Im using 24" viewsonic LCD with 1920x1080 res... i can see some kind of wave effect on my screen for my PC01. just minor but yet annoying. as for when i switch to my PC02, it is worse!!! the wave effect more obvious and sometimes i hardly read things on the screen.
note: top part of the screen don really have those wave effect thingy.... bottom part minor.. only middle part is has the obvious wave effect thingy. -.-
this i personally dont think is LCD problem as i already did some test.
1st- direct plug the cable into graphic card (without go thru KVM), i get perfect sharp screen.
2nd- using lower resolution such as 1280x720 or 1600x900, i don get those wave effect even it goes through KVM switcher. (the lower the resolution, the less wave effect.)
can anyone helps me on this?
im stucked. btw since im using KVM switcher, im using D-SUB cable. i think usually ppl call that analog?
yea... that's it about my problem...
hope to get some help pls...
