Screen Resolution Fix not working: Attn. Doug Knox
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
I've installed the fix for keeping users' screen resolution settings
according to the "Read-me" file directions. Whenever I try to run the
program, I get a message that says: "Runtime error '383': 'Text' Property
is Read-only". Am I doing something wrong?
Dianne
Remove SHOES before emailing:
dskag@comcastSHOES.net
http://www.graphicdeesign.com
http://therosary.home.comcast.net
Welcome to the MSDN Library (Error 383). Doug Knox may have some
more info to add.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/vbenlr98/html/vamsgsetnotsupported.asp
Display Resolution and Color Depth Settings Apply to All Users
http://support.microsoft.com/default.aspx?scid=KB;EN-US;Q281565&ID=KB;EN-US;Q281565
Some days you're the windshield,
some days you're the bug.
> Dianne
More info on the problem I submitted earlier. I installed the program on my
desktop and it works fine. It is only on the laptop that I get the Runtime
error '383'. Both are running XP Pro. Is there a setting that I need to
change on the laptop to allow the program to startup? Thanks.
Dianne
"Dianne" <dskag@graphicdeesignSHOES.com> wrote in message
news:%23BcFCBaeFHA.2844@TK2MSFTNGP14.phx.gbl...
> Property is Read-only". Am I doing something wrong?
> Dianne
