[SOLVED] Seagate FireCuda 520 Heatsink is Need or Not?
JohnnyR2D2
40
Hello everyone,
Hope I can get some insights from my question below and help me decide what to do.
I'm building a new RIG (current is under my signature) with the following:
Intel Core i7-9700K 3.6 GHz 8-Core Processor (Bought already)
Noctua NH-D15 CHROMAX.BLACK 82.52 CFM CPU Cooler
Asus ROG MAXIMUS XI HERO (WI-FI) ATX LGA1151 Motherboard
G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3200 Memory
Seagate FireCuda 520 500 GB M.2-2280 NVME Solid State Drive
Seagate FireCuda 520 2 TB M.2-2280 NVME Solid State Drive
Sapphire Radeon RX 5700 XT 8 GB NITRO+ SE Video Card (Bought already)
Cooler Master MasterCase SL600M ATX Mid Tower Case (Bought already)
Corsair HX Platinum 1200 W 80+ Platinum Certified Fully Modular ATX Power Supply (Have it already)
My question is specifically in regards to the Firecudas 520. They don't come with a heatspreader or heatsink included and neither the Mobo has heatsink for M.2 drives. With that said should I worry about getting an aftermarket M.2 heatsink or no need? And if yes since this is a two-sided M.2 is there any specific heatsink I should look? Does anyone have any recommendation for a good heatsink?
Last but not least , the reason I'm choosing the Firecudas are basically two (advertised endurance and warranty from Seagate which I already used more than once and never had any issues with).
Thanks in advance,
JohnnyR2D2
Run it, check temps. Best way to go since it depends on the system and the workload. Generally you do not need a heatsink. The drive will begin throttling around 70C - if you're bumping up against it, there are plenty of options to cool it, although I prefer to just cool the controller.
According to Tom's Hardware review the Firecuda 520 doesn't come with a heatsink because Seagate assumed the MOBOS will have one preinstalled which is not the case of my MOBO. I just want to make sure I will not need a heatsink and in case I need it if there any one someone could recommend.
Reactions: JohnnyR2D2
Thanks a lot. I'll do that since I can always buy a heatsink later if need it. One last question. My MOBO has the M.2_1 between the CPU and the PCIEX_16 where I normally plug the GPU and the M.2_2 at the bottom rear of the Mobo. Since I'm going to use the 512 GB for the OS with all the usual applications and the 2 TB to install my games do you think it's better to have the 2 TB in the M.2_1 (I read gaming really doesn't have too much read/write) and the 512 TB at the bottom away from the heat of the CPU and GPU? Or just doesn't matter?
