I have a company-issued notebook machine that spends most of its life in a docking station, using the wired network connection. The wireless connection to our secured LAN is also open.
When I remove the machine from the dock, I lose most of my network connections. In one sense this is reasonable: the Putty sessions, ISQL windows, even Microsoft Outlook had connections through the wire, and these are broken. But it would be really nice if they failed back to the wireless connection, not at the individual application level but through something I set up at the OS level.
Yes, I could disconnect the cable from my dock and all my connections, all of the time, would be wireless. But that is slow and inelegant.
Is it possible to set up my network connections so that apps can basically see the two as interchangeable? So that if one gets cut off the other is used seamlessly? Something like channel bonding?
I am running Windows 7 Pro 64-bit version.
