Archived from groups: alt.sys.pc-clone.dell (More info?)
I'm trying to put a Western Digital 60G hard drive into my old
dimension 8200. It currently has a WD 80G as primary master. I
installed the 60G as primary slave. Both drives have the cable select
setting. The problem is that the 60G HD only shows up 8G as its
capacity. Does anyone know how to fix the problem?
Thanks
Thanks
