Secondary Hard Drive
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I had to repair my operating system because of a corrupt file on my main HD.
After repairing the file windows renamed my secondary hard drive and won't
let me access it without reformatting it first. Is there any way to gain
access to this drive without reformatting it?
Let me suggest that posting 3 times on the same newsgroup is just madness.
You won't get your answer any quicker.
Windows will not under any cirumstances rename a hard drive or view it
unreadable, if it was properly Labelled and Formatted in the first instance.
It may be better to look into why you needed to perform the repair install.
SHould the drive have some user files that you are unable to access as a
consequence of creating a different profile during the repair, try this
proceedure below. If it doesn't prove successful , then repost with the
exact reasons that caused you to perform the Repair.
How to take ownership of a folder
Note You must be logged on to the computer with an account that has
administrative credentials. If you are running Microsoft Windows XP Home
Edition, you must start the computer in safe mode, and then log on with an
account that has Administrative rights to have access to the Security tab.
If you are using Windows XP Professional, you must disable Simple File
Sharing. By default, Windows XP Professional uses Simple File sharing when it
is not joined to a domain.
For additional information about how to do this, click the following article
number to view the article in the Microsoft Knowledge Base:
307874 How to disable simplified sharing and set permissions on a shared
folder in Windows XP
To take ownership of a folder, follow these steps:
1. Right-click the folder that you want to take ownership of, and then click
Properties.
2. Click the Security tab, and then click OK on the Security message (if one
appears).
3. Click Advanced, and then click the Owner tab.
4. In the Name list, click your user name, or click Administrator if you are
logged in as Administrator, or click the Administrators group. If you want to
take ownership of the contents of that folder, select the Replace owner on
subcontainers and objects check box.
5. Click OK, and then click Yes when you receive the following message:
You do not have permission to read the contents of directory folder name. Do
you want to replace the directory permissions with permissions granting you
Full Control?
All permissions will be replaced if you press Yes.
Note folder name is the name of the folder that you want to take ownership
of.
6. Click OK, and then reapply the permissions and security settings that you
want for the folder and its contents.
Also, like I added last time:
http://support.microsoft.com/default.aspx?scid=kb;en-us;823306
Nathan McNulty
> Properties.
> appears).
> Full Control?
> of.
