E6300 Stock speed
Gigabyte DS3 latest BIOS
X1900xt 256
GSkill DDR2 800 4-4-4-12 (Blue spreader) @2.1v
Aspire 500W PSU (Clear Blue Model)
Thermaltake Big Typhoon W/ Silverstone FM121 fan @ 1000RPM's
Voltage Idle From Easytune
VcoreA 1.25
+3.3v 3.32
+12v 12.49 (kinda high?)
CPU Vid 1.32 (??)
Temps Idle Easy Tune
System 39c
CPU 23c
TAT- 39c both cores
Volts Load Using TAT recoded from Easy Tune
VcoreA 1.33
+3.3V 3.32
+12V 12.36
CPU Vid 1.32
Temps Load using tat recorded from Easy Tune
System 39c
CPU 43c
TAT full load 55c core0 51c core1
Story:
My PC suddenly died the other day. Took my two days to narrow it down. The CPU died and I replaced it with another E6300
Worked fine for 1 day and I overclocked it to 400x7 1.325v and Ram at Factory 800 4-4-4-12 2.1v
Temps stayed below 60c under normal use and seemed stable
Last night running idle with Torrent program, CP started restarting in a fucKedup way.
It wouldnt turn on the first 5 times and the 6th time it turned on @ 2.8
I reset everything to Failsafe defaults and it restared again browsing the web.
I set ram at 2.1v (from 1.8v with is below specs) and I typed this.
Any ideas??? I'm thinking either Motherboard or PSU.
X1900xt 256
VcoreA 1.25
+3.3v 3.32
CPU Vid 1.32 (??)
System 39c
CPU 23c
TAT- 39c both cores
VcoreA 1.33
+3.3V 3.32
+12V 12.36
CPU Vid 1.32
System 39c
CPU 43c
Story:
