Question Should I return?(XFX RX 5600 XT RAW II)
lesziii
Commendable
Mar 18, 2020
5
Recently purchased the XFX RX 5600 XT RAW II from Best Buy, I paid about $300 because they refused to price match their own website.
Problem is, I still need case fans for my PC, and there are cheaper models on Amazon of the RX 5600 XT.
Would it be worth returning the card and grabbing a cheaper one.
Also, would I be losing anything that the RAW II model offers, or is the RAW II model pretty much just a reference model.
As long as it doesn't only have 1 fan, its good. 3 fans are usually the best. Don't forget to update your gpu bios for free performance.
Yep, did that with the XFX model I grabbed.
Simply put though, the only reason I've considered a return is simply due to feeling like I was mislead on price.
I can't seem to find anything on the Gigabyte model with two fans however.
Appreciate it, would like a little more feedback before I make the decision.
I've got six days left to decide, so if anyone could suggest before I'd be thankful.
