Sorry that didn't work. At this point it seems you might be at the next level of troubleshooting, which might require spending some money.
- The PSU could be the issue. Best way to test it is with another PSU (there are test rigs ... if you knew a shop that had one, great ... otherwise they are cost prohibitive).
- This could be a heat issue with the CPU or VRMs. Some fans might help, but there is no easy, conclusive test.
- We have not even talked about memory. Fortunately, that is an easy test as you can run the machine with one stick in different positions or run memory testing software.
Right, I was thinking of an upgrade anyways. So, please help me decide as I am not much familiar with on how to proceed regarding the hardware specs.
HWMonitor will show you the actual CPU core temps....and clock speeds. If core temps not reaching throttle temps, but throttling appears to be occurring, then the MB would be the one doing the throttling (if it is even occurring), potentially due to VRM temps and/or power limits...
Cooling off the VRM circuitry with a simple house fan and an open case would seem a simple thing to test....
If results the same, I'd not think VRM throttling an issue....
Naturally, a PSU can easily cause insta-power-off symptoms as well....at some point, it will also need to swapped (at least temporarily) to rule out as a potential cause...
Well, I was thinking of upgrading it all together, so please help me alongside the others on how to proceed.
It could be the very poor PSU , but that board has no heatsinks on the VRM , so most likely the CPU is throttling and shutting down. That board shouldn't have a 125w CPU mounted on it. Very poor power phase and thermal design.
Well, it has served me well all these years without any problems. So, are you suggesting I need to change the mobo? I don't know what VRM is or what it does.
At this point, I am quite frustrated because I've not been able to use my PC properly. So, here is the thing. I am thinking of upgrading my desktop and all the parts within it but I won't be able to do it all in one-shot.
Now, I don't know with which parts I should start first but these are the things I've on the mind.
CPU:
Intel - Core i7-8700K 3.7 GHz 6-Core Processor
Cooler:
Corsair Hydro Series, H80i V2, 120mm Dual Thick Radiator, Dual 120mm PWM Fans, Advanced RGB Lighting And Fan Control With Software, Liquid CPU Cooler
Motherboard:
ASUS TUF H370-PRO GAMING Motherboard (Intel Socket 1151/8th Generation Core Series CPU/Max 64GB DDR4-2666Mhz Memory)
RAM:
G.Skill F4-2666C15S-16GVR Desktop Ram Ripjaws V Series - 16GB (16GBx1) DDR4 2666MHz
PSU:
Antec Hcg-1000-Extreme Smps 1000 Watt 80 Plus Gold Certification Fully Modular Psu With Active Pfc
GPU (Either one):
MSI GRAPHICS CARD PASCAL SERIES - GTX 1070 TI ARMOR 8GB GDDR5
Msi GeForce RTX 2060 Ventus XS OC 6GB GDDR6 192-Bit Gaming Graphics Card, Active Fan Control, Metal Backplate
GALAX GeForce RTX 2070 EX (1 Click OC) 8GB GDDR6 256-Bit Gaming Graphics Card Active Fan Control Metal Backplate RGB Effect
SSD:
Samsung 860 QVO 1TB Internal SSD (MZ-76Q1T0B)
HDD:
WESTERN DIGITAL DESKTOP HARD DRIVE 4TB BLUE (WD40EZRZ)
Now, I was thinking of changing the Cooler & PSU first and see if that solves the problem. At which point, if my PC starts to function normally - I'd be able to get the remaining over the consecutive weeks. So, something like ->
1) Cooler & PSU --> 2) Mobo, RAM & CPU --> 3) GPU --> 4) SSD & HDD
Just want to know from you guys, if that is the ideal way to proceed? And if all the parts I shortlisted above are compatible. Not much of a tech guy so would appreciate the fullest help.
Regards.
