Signal-to-Noise Ratio Quality
lvyk
Is it big difference btw Sound Blaster®
Live! 24-bit 100db of Signal-to-Noise Ratio with Sound Blaster® Audigy® 2 ZS Series 108db of Signal-to-Noise Ratio Quality?
What about if my speaker only support up to 100 db of Signal-to-Noise Ratio Quality? like Logitech® Z-5500 Digital.
Will I still get the benefit of 8 db if I use Sound Blaster® Audigy® 2 ZS Series with 108db of Signal-to-Noise Ratio Quality
it makes a difference to any high spec Speakers.
get the ZS u have a Vgood set of speakers they deserve the best.
<font color=purple> MY FINGER IS ON THE BUTTON! </font color=purple>
8db is noticable, but at a sound level of over 100db it's not that great.
I think the drivers for the Audigy 2 ZS suck a little less than the Live drivers.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Hi,
You confuse between two terms that sound the same but are completely different. The SNR of your soundcard will determine how low is the noise floor below the maximum level of your card. Therefore, this makes a big difference if you intend to use your card for recording. You should check the output SNR of the card if you want to get a numeric idea of how good is the SNR.
Nevertheless, the soundcard specs are usually not accurate. Given the speakers you use (which might sound good for home uses, but are definately not pro audio monitors) you will hardly notice any difference in SNR (the two cards might sound different due to other differences, but you should be able to notice this).
Tom101
Pentium 4 2.66gHz ; 1024MB DDR ; Video - Intergrated
