I've been having problems for a few weeks in uploading specific sites like Twitter and Artstation. Usually when I start the system or restart the sites open normally in Opera GX which is my default browser, but after a few minutes the sites stop loading fully, load only by half, (like the image below) do not load or in the case of Twitter accuses the message of "ERR _ CONNECTION_RESET".
I have done several procedures:
System Restore.
Realtek Driver Reinstall. (It worked for a few days after this procedure, now even repeating or updated drivers no longer works.)
Restore the modem to its factory settings.
Restore Opera and other browsers that I tried for the factory setting, such as Chrome and Firefox.
I disabled the proxy server.
I tried public DNS servers, like Google's.
I deleted the hosts file in "C:WindowsSystem32driversetchosts".
I did a virus scan with Malwarebytes.
I checked the Applnit_DLLs record, it's empty.
I disabled the Windows firewall.
I restarted the CryptSvc service.
I called my Internet service provider.
I tried on other browsers like Firefox and Chrome, no results.
I tried to disable Opera's hardware acceleration without results.
The commands:
route –f
sc config cdpusersvc type=own
ipconfig /flushdns
netsh winsock reset
netsh int ip reset
ipconfig /release
ipconfig /renew
chkdsk /f /r /x
ipconfig/flushdns
None of the procedures worked, however, the websites typically open only under two conditions: using the Microsoft Edge browser and Opera's native VPN. If I disable the VPN the sites do not load again. I'll be grateful if anyone can help me, because my options are already exhausted, I tried almost everything.
My modem/router model: Sagemcom F@ST 3284u HP NET
PC config:
Motherboard: Asus M5A78L-M/USB3
Power supply: Corsair CX600M
Network adapter: Realtek PCIe GbE Family Controller (192.168.0.10) with driver version: 10.34.307.2019
Operating System: Windows 10 Pro 1903 - Build: 18362.295
My ISP is "Claro Net", 60 Mbps.
If there's anything more I need to inform, just tell me. Thank you for your attention.
System Restore.
The commands:
route –f
ipconfig /flushdns
netsh winsock reset
netsh int ip reset
ipconfig /release
ipconfig /renew
chkdsk /f /r /x
ipconfig/flushdns
PC config:
