SONY DCR TRV 460 simpleton questions
G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
Hi All!
I am planning to buy a CAMCORDER.
It will be my first one.
I have never used a camcorder before.
TRV 460 Features I am impressed about are
# Its Night Shot plus , Image stabilizer,
LCD Display, USB streaming for WEBCAM and PC
My basic requirements are to do the following easily.
Almost like a plug and play.
# I should be able to connect it to TV and
see what is being captured by camcorder
# Connect it to a VCR and record what is
# Connect it to a computer and save what is being
captured by camcorder. So that I can edit.
? Does TRV 460 do these?
? For saving on computer does SONY give any software
? Can we get any other freeware or any commercial software for editing such?
? What is this requirement of a higher memory stick 64MB, 128MB about?
What is it for? Is it really useful, if I donot intend take still pictures
with this TRV460.
I really donot care for a Digital photo still pictures, as I intend to use
a 3 mega pix Digital camera for that.
I saw conflicting reviews on Google and thought I
will contact you all with regards to this.
thank you for your reviews and response,
I really appreciate them,
-M.Degallo
"Mary Degallo" <MaryDeGallo@yahoo.com> wrote in message
news:2b4437ac.0407040413.7eadb69c@posting.google.com...
> Hi All!
such?
pictures
> with this TRV460.
use
> -M.Degallo
Yes, the TRV460 will do the above.
The Software which is supplied was of no use to me.
If you have Windows XP it has movie maker installed. A good editor to start
with. There are plenty of other freeware and commercial software as
options.
Memory stick is of no use to me.
The TRV460 is a Digital8 camcorder. It is excellent for playing back and
digitizing analog Hi8 and 8mm tapes. That is the only reason I purchased
mine. The Digital8 format is dieing. Unless you need the analog Hi8 and
8mm tape capability, I would not reccomend the TRV460. There are plenty of
MiniDV format camcorders out there to choose from.
Go to www.camcorderinfo.com and spend a lot of time reading.
If you want quality video transferring by FireWire, i.Link or IEEE 1394 (all
the same thing) is the way to go. The USB transfers are of low quality with
a variety of problems.
Rich
On 4 Jul 2004 05:13:13 -0700, MaryDeGallo@yahoo.com (Mary Degallo)
wrote:
>Hi All!
It is Sony's current best Digital 8 camcorder, not bad for home use.
But if you don't need 8mm/Hi8 tape capability, you might want to look
at similar featured MiniDV camcorders. The MiniDV format is more
popular -- only Sony and Hitachi (maybe Sanyo?) do Digital 8. The
smaller MiniDV size can be a factor too, if you like smaller things to
handle.
Yes. It comes with analog video cables, so you connect to a TV or
VCR -- especially convenient if you have front connectors for this.
To hook up to the computer, you need a firewire port and cable
(IEEE1394 ports, Sony calls this iLink on its camcorders and
computers). The cable doesn't come with the camera.
Yes, but it isn't that impressive to me. WinXP's Movie Maker is
probably better for starting out -- free -- and there are many other
options.
Yes -- I mention one, there are lots of others.
> with this TRV460.
Memory stick is for still pictures only. It can also do low res
mpeg1 videos, but that isn't a very effective use either.
*-__Jeffery Jones__________| *Starfire* |____________________-*
** Muskego WI Access Channel 14/25 <http://www.execpc.com/~jeffsj/mach7/>
*Starfire Design Studio* <http://www.starfiredesign.com/>
I have a TRV340, bought second hand, good value at that, works well, has
good optical zoom, unlike the new Sonys it has real push button to control
things, not a push screen to get gunked up with prints, has a great lens but
lack some manual control.
I haven't seen a consumer digital video that really works well in low light,
the best I have seen are acceptable.
Think about how much you want to spend and what you want in the long term,
mine was bought for me to learn and to be safe in the hands of a 10 year old
ie not too much value is it gets dropped.
This review of the 460 sums it up.
http://att.com.com/Sony_Handycam_DCR_TRV460/4505-6500_7-30671273-2.html
If you are buying to have a camera for several years then you should look
at the higher model miniDVs
phil
"Jeffery S. Jones" <jeffsj@execpc.com> wrote in message
news:bgoge01e9c607ult7g9sbic5v082dkrpjb@4ax.com...
> wrote:
> >Hi All!
> handle.
> options.
such?
pictures
> > with this TRV460.
use
